1973dusterkid
Watch This
How hard and what parts would I need to put a 340 in a 1973 duster that is a slant 6 225 stock
hey, i cant keep up with all the new threads you are opening. it may be asier for you to just keep it all to one thread, and you will get more replies that way, and i answered this question in one of the other threads!
The big parts
Motor
Small block tranny
either a set of swap motor mounts or a V8 K frame with mounts
Exhaust
it will fit
I did this swap. Got the motor mounts from Schumacher, amassed all the parts..... Ie; motor, trans, etc. Pull the slant 6 out, painted the engine compartment and installed the v8. Oh and I went from an auto to a four speed. Very easy to do if your mechanically inclined.
I'm thinking at the moment this is going to be an engine swap on a budget. am I correct? You signature also says its your first car? I would just go with a 318 with some bolt ons for now. You can do it cheap and get some decent power. Later down the road build the killer motor. 318s can be had cheap and even sometimes free if your lucky!
Yes, the small block mount's like the ones in this thread that AdamR postedwould I need new mounts for the 318
318's run REAL good with 360 heads. You just have to make sure that you get the right heads for the right block to the best of my understanding. (ie LA heads on an LA block)
I got to see if i can find me a block
