2500 HP V-16 by Chrysler from WW II
mguner
How many is too many?
Amarillo,TX
The cylinder bores are not staggered from bank to bank. Notice the split rod and common bearing shown in other pics from the link below. This was used in the XP-72 a modified version of the P-47 thunderbolt. Notice it made that power at 3400 RPM.
http://www.enginehistory.org/Museums/chrysler.htm
schweet..stick that in ur dart and smoke it...or is it.... smoke'm!!!! LOL :-D
My father is an air power nut and is crazy for this era. A bit of knowleage has rubbed off on me as wel as a like for the era aircraft.
This particular Thunderbolt was the faster ever produced. (I'd need to look up top speeds to be accurate) I think top speed was top 450 MPH. I think it toped at 472 MPH. For a piston driven aircraft, this is extremely fast.
Aircraft design, and engine have it's limits.
Engine RPM and ultimate power output and wing design are probably at it's max here. (Mostly wing)
Chrysler also produced engines for tanks. A weird design , designed to run even if a bank of cyilders were to be knocked out.
