investigator
has anyone done this and what has to be done to put it in a previously 6 cylinder dart. What are problems and downsides and what shrouds work.
ECP is a brand new radiator going in a 1968 Dodge Dart that was a six-cylinder converting to 8 putting in a small block 360 proximally 420 horse originally rated at 390 Mopar performance 360 what other information would you needTypical investigator, asking a question with near zero information as to what the question pertains to.
What the heck is a 26 inch ECP?
A radiator maybe?
Yeah being aged person I have learned that I don't know it all and I'm willing to listen to those that have experienceLawdy.
No problem I will try to answer all questions Mopar performance 390 engine not installed yet has RT heads 202 valves Edelbrock Aluminum Intake headers Street Demon carburetor I believe a hundred and eighty degrees on the cam 727 automatic transmission no AC no power steering my first Mopar project but not my first project be glad to answer any other questions by the way the radiator has automatic transmission cooler built in 2 1"tube aluminum radiator please feel free to ask for any more information you need I am tickled to death to get any help I canThe problem is most of us dont know Engineered Cooling Products. Or how many rows is in your particular part #. Or if you have aluminum or iron heads. And how much duration your cam has. Does your car have a/c? Auto or stick? Trans cooler? What size fan you running? Was a little vague and needed some info, thats all. Lots of help on here, trust me.
Is the lower support you were referring to the piece of sheet metal that goes down and curves back and runs all the way across from left to right underneath the radiatorIs this the radiator you're talking about? 26" Small Block Mopar Radiator
If it is, the one concerning thing that I see is how tall it is. It lists the height at 23 1/8". By comparison, the ECP radiator that is actually marketed for A-bodies is 22" tall.
I will say right now I haven't installed an ECP radiator. I have installed a Champion 26" radiator in my Duster, before the Champion CC374 became the CC374B and became too tall to fit without cutting the lower radiator support brace. The radiator I have in my Duster is ~22 3/4" tall, and it pretty much sits on the lower support. The new CC374B is 23.5" tall to the cap, and it will not fit without cutting. The 23 1/8" measurement will be very tight. I'm not sure it will clear without modifying the lower support brace.
As for the radiator size and cooling, it should be more than enough. The Champion I run is a 26" 3 core, and the iron headed 340 in my car pushes 400+ hp. With the Ford Contour electric fan set up I run the car stays cool and consistent even when it's 110* out. Here's the link to my install in my build thread. My car was also originally a /6 car with a 22" core support opening. My "new" '74 Duster- or why I need a project like a hole in the head
