Is the lower support you were referring to the piece of sheet metal that goes down and curves back and runs all the way across from left to right underneath the radiator
Yup, that's it.
Thank you very much 390 horse Mopar performance 360, changed intakes and carb have MSD Holley electric fuel pump not installed yet though obviously had 2,000 miles when I bought it used, heard it run paid paid 3500 for all in picture + fuel pump and 727 automatic transmission with performance Kit from some famous Mopar transmission builders. think I'm going to shut down for the night and do some research thank you to everybody for your help hope to visit again sometime PS anybody gets near New Waverly Texas 60 miles north of Houston let me know would like to meet you.Nice engine.
Nice to know if they dont back it up. Did they claim you altered it?I bought one of their 22 inch radiators. Nothing fit properly. So tall I can't use a lever cap. Had to grind out the mounting holes, and weld the other side of the holes/slots so a bolt and washer would fit. After all that, the stock shroud won't work due to the mounting rails on the radiator. Wouldn't cool at low speed. I had to hand build a shroud. Called them up,and got nothing. Run away. Far away. This is a 69 Dart Swinger 340.
Sure does.My main concern, was, where do I find a fan shroud to work with your radiator? Reply, we don't have one. Well, if you are going to change the way a shroud is mounted common sense would be to build a shroud that fits. I didn't bring up about changing the mounting holes, I just wanted a shroud. They made it with a flange on both sides to mount a shroud to, but it sits out about and inch or so from the radiator, so you have this big gap at the top, and bottom. Defeats the purpose of a shroud.
I installed To My Hood closed it and measured from bottom radiator support to the recessed area where Cap fits and came up with 24 and an eighth inches Auto work did you have to cut or trim any of that sheet metal at the bottom of the inner fenderYup, that's it.
My bad I meant the metal on top of my finger not what I'm actually pointing to but thanks it's nice to know I won't have to cut any talk to Champion today and they gave the measurement overall to the top of the cap on the filler neck as 23 3/4 looks like I am in business thanks to you I will wait to purchase though because they give you 60 days guaranteed to coolNo, no trimming. Not for mine anyway. And that "sheet metal" you're pointing to is your frame rail.
Good luck using Champion. You'll need it.
I say that because of both what I have read and seen, first hand. And no, I don't plan to run one. I've never seen problems with Be Cool or Griffin, yet there are hundreds of threads online about chinese imported radiators that don't cool well.......whether champion or whatever other brands there are. Lots of people have great luck with them. "I" will not take a chance on one and "I" will not recommend them.
I have also not tried eating dog crap, but I don't recommend that either.
Here's an entire thread about griffin radiators not fitting properly, including some of their "direct fit" radiators that start at over $600 and are supposed to bolt in, but still required modifications.
Griffin Rad fitment issues
Griffin's direct fit radiators are $600+. Be Cools direct fit radiators are $700+. Their cross flow radiators are cheaper, but they're universal radiators and need mounting, and then you have to figure out new radiator hoses.
So no, griffin and be cool radiators aren't 100% problem free. And for 3x the cost, you'd think they would be. I'm ok with making a few small changes to the mounting holes if it means saving $400 and still using stock hoses.
Regardless, the OP never asked about Be cool or Griffin radiators. Probably because a $600 radiator wasn't in his budget. And since you've never used or installed a Champion or ECP radiator, I don't see how your comments are useful here. I've read a lot of those horror story threads about champion radiators, and I read a lot of them before I bought mine. Some are legit quality issues with champion, it is a cheaper radiator and they have some QC issues sometimes. And some of them were replaced under warranty by champion too. But some of them have more to do with inadequate fans and cooling systems outside of the radiator too. Put a crappy fan on a Griffin and you'd have the same problem.
Bingo.....With the right measurements, a chimp could do a good job at fitment. But you cannot fix a radiator that will not cool......which is what "I" am talking about.
I am probably going to switch my son's car away from a Champion to a Griffin 1.25" tube cross flow rad. They run around $275, not the $620 that the direct fit Griffins cost. So 72Blunblu needs to recognize that there are multiple lines in the Be-Cool and Griffin brands, and IMHO is unfairly biasing the readers against them based solely on the cost of their more expensive product lines. This is not helpful to the general readership who are looking for the best cost and best cooling solutions.
I conservatively compute the cooling capacity to be in the 15-25% range better for the 2x1.25" row crossflows versus the 3x3/4" downflow Champion. We need to get better cooling capacity in the rad due to:
- the smaller early A body engine compartment not being as good for airflow IMHO
- having an AC condensor and external trans cooler up front of the rad.
The 3x3/4" Champion is just not doing it for overall cooling capacity at interstate speed, when moderate HP is being produced.
And FWIW I would pick a 2x 1" row rad over a 3x3/4" row rad for a slight overall cooling capacity advantage. The ECP's and Be-Cool's have that advantage. This does not include the apparent coolant flow limitations that some 3/4" tube cheap rads have been reported to to have. I can't shed any more light on that last issue; I am just relating what I have read on that matter, and have not really examined what is going on there.
Nevermind.
I am beginning to suspect that part of the highway speed cooling 'equation' is the engine compartment size and subsequent air flow. We are dealing with a smaller compartment than your later Duster. There is nothing especially constrictive in the engine compartment: 340 small block, AL heads, headers. In front of the 22" rad is a full width AC condensor, and a half width trans cooler. So there is some flow restriction in front. The hood to core support seal is in place. HP production at interstate cruise should not be too much; there is nothing unusually 'un-aerodynamic' about the car....well, besides being an early A body!As far as your Champion not cooling at speed, I'm not sure what to tell you. Is it a 26" 3 core or a 22"? My Duster runs down the freeway at 80 mph with the temp gauge at 190* even when it's 100*+ outside. The electric fans never come on when the car is moving at highway, let alone freeway speeds, regardless of the outside temp or engine speed. When it's colder than 70* outside it will bounce off the 180* thermostat while on the freeway. And that's a 400+ hp, .060" over, 9.8:1 compression, iron headed 340. It doesn't have an A/C condenser up front (which is significant), but it does have a 26" radiator sitting behind a 22" radiator support.
So it all comes down to airflow and coolant flow and heat transfer. Coolant flow is (hopefully) better with a Milodon high flow pump. But that can only do so much if there is a flow restriction elsewhere.
