IMO....... For what it's worth.......
The 260 comp is the way to go, the 268 will dog even with 3.55 gears, no matter what you do with timing, until compression gets over 9-1....
The 260 is the best all around 318 cam Comp makes, but if your looking for the best bang for the buck, it's just short of almost there.....
Stay away from dual energy type cams with stock 318 heads, manifolds or no, the added exhaust duration just makes the little motor less snappy from idle, to add a couple hundred RPM to the already weakening power band. (Worsens MPG too)
IF it were me, in other words, whet I always do when I have a choice in the matter, say.... The motorhome I jsut finnished a 318 for..... call ISKY, and have them grind the 262/262 with a 104 LSL, and get excellent throttle response, power to 5K, and great MPG.... And last but not least, a nice 800RPM rolling idle chop.
BTW, Rotella 30W, Zinc additive, T stat out, front studs removed from heads to bleed air, and we woofed the first lobe on that 275HEL or whattev in a 360 tuesday......... Never had any cams go flat but Comp and Edelbrock....... Wherea's the 228* solid in my 390 was started at an idle, warmed up, and then driven like normal and gee it lived.
Comp Comp Comp, to each his own, I would just check ISKY, LUNATI, and ENGLE. ISKY being the best if you want to talk to a cam guy in person about exactly what you want.
