27 T Rat pickup
wannadrag
Waupaca,WI
Rating - 75%
3   1   0
Rat Rod pickup based off a 27 T closed cab cowl and home built from there back.Frame is a 47 IH pickup,rear axle 64 plymouth 8.75,front axle 40 Willys,Steering column and box 37 chevy.350 4 bolt engine and 350 trans both good.Had the engine running on the stand 2 days ago before i put it in
Engine and trans are mounted,steering is done,cab and box mounted,chassis is done.Shifter,gas and brake pedal mounted.Been working pretty steady on it so progress continues.No extra parts or title.Might take some thing mopar in trade,daughter just turned 16 so i could use a driver for her duster or dart with a 318.Cash is good also $2500.Located in central WI near Waupaca
