273 commando carb
PredatoryFish
Member
Portland Oregon
does anyone have the carb number or specs for this carb easily available? I did a couple of quick searches but i havent come across anything yet.
1965 manual trans: 3853s
1965 auto trans: 3854s
1966 manual trans: 4119s
1966 auto trans: 4120s
1966 manual trans with CAP: 4121s
1966 auto trans with CAP: 4122s
1967 manual trans: 4294s
1967 auto trans: 4295s
1967 manual trans with CAP: 4304s
1967 auto trans with CAP: 4305s
If using an original Intake manifold The 600 Carter and 600 Edelbrock secondary valves are too large to open. If I remember correctly.
that is correct but only a hair. I doubled up the gasket under the carb, works fine.
FWIW, I have 2 cars with 273 Commando engines that came with the 9636 Eddy carbs on them. I didn't think that these cars ran that well with the Eddy's. I was able to find a 3854, and a 4120 Carter and I feel these cars run better with the original carbs on them. But it was hard to find both of them. But for me, it was worth the effort.
