amusingarts
Hi guys,
I've finally gotten my engine together and started. Its a 273 with headers a ABF 4 bbl and an Engle cam. It seems to run OK but I haven't taken it out on the road for a real good run yet.
The question I'm hoping someone can help me with is what should I set my ignition timing at? I appreciate any help you guys can offer.
The cam specs off of the cam spec sheet are as follows;
Exhaust lift .405
Running duration 244 degrees
Valve Lash intake .018 and exhaust .020
Gross cam lift .270
Duration 208
Lode centers 110 degrees
Intake opens @ -4 and exhaust closes @ -12
A. musing
Exhaust lift .405
Gross cam lift .270
Duration 208
A. musing
