273 manifolds - SB pulleys - moore
swing69
I’m just an old guy……
Central NJ
1) Looking for set of 273 OEM manifolds. shipping to NJ. Nothing broken please, but bad flapper OK.
2) set of 3 SB pulleys: crank, WP and Alt., no AC or PS. With Alt brackets if possible.
i will sell for 60 shipped let me know thanks
joe
I can pick the pulleys up at the pick-a-part today if you want, off that '66 Barracuda I mentioned in my other thread you responded to. Yours for cost plus enough for me to buy lunch and shipping. :-D Will send you a PM with my phone #.
It shouldn't be more than $10-14 for the alt. bracket and I have no idea how much pulleys will cost.
Alternator was gone though, so the Alt. pulley will not be available.
Those pictures of manifolds are for 67 and up (at least the drivers side is). the pass. side is the same though. Here is a pict of the manifolds that I need. They are pre-67, 273 only.
Pulley set: I should clarify; I need an alum. waterpump set, which will be different than the steel waterpump set on 273 and early 318LA motors.
I could use either or both pulley sets:
If a 273 steel waterpump, I need the crank pulley, waterpump pulley, bolt on timing tab, and alt. brackets, including the small offset head bracket.
If a later alum. pump 318: I need the alt bracket (no head bracket), crank and waterpump pulley - no bolt on timing mark, mark cast into alloy timing cover.
I'm only interested in complete sets, single pulley NO AC or PS cars please. thanks!!!!!!!
Well, if the manifolds listed above aren't the ones you're looking for, I have a set removed from a 66 cuda. I personally removed them myself. I am asking $75.00 plus shipping, or $100.00 blasted and painted with high heat cast iron grey paint. Let me know if you need them, Geof
Update: I now have the 273 pulleys and manifolds.
Still could use a 71 (?) and later, small block, single groove crank pulley, WP pulley (alloy WP) and alt. brackets set. Yes, all is available repop....but good used are fine.
Thanks
Mike
