toypar
I am in the process of gathering up parts for a V8 swap in a 4 cylinder jeep I have. I have a 40,000 mile 66 273 I used to have in a Toyota pickup years ago. I had installed a 340 cam and valve springs and ended up spinning a rod bearing. Pulled it out and installed a 318. Anyway...
This jeep I have has a 4 cyl, I could swap a 4.0l six in it, but looking at the stock specs of a 2v 273 it produces max torque at 1600 RPM where as the 4.0l produces it at around 3500. HP and torque and weight are very close between the 273 and 4.0l.
I don't really want a powerhouse, just something to idle around and cruise decent. I really want to build is engine to get the best mileage possible. I am thinking probably putting back to stock down to the solid camshaft and 2v would be ideal. (Solid might get better mileage due to lower friction on the valvetrain over hyd???)
I have had no luck finding a solid replacement cam, and looking at engine specs with the 235hp 273 cam shows peak torque at 4000!! I believe that is to high for my application.
Any suggestions to another cam, intake or carburetor combo for an efficient engine??
