Most of the external parts will transfer, but you may need to use spacers and such to get everything lined up. You will also need a 340/360 driver side motor mount and a 360 car oil pan (center sump).
I have a Magnum 408 in my 69 Barracuda and most of the stuff I replaced, but I did reuse the Alternator brackets (with an extra spacer), Power Steering and a few other things. I chose to go with a 70 up timing cover and water pump, otherwise they would have transferred over. BTW the engine in the car was a 318.
valentek
