That wagon should not be that heavy.
What engine do ya figure '64 cuda was adjusting valves on while it was running? I would think a Shivvy....
If you are using Original 273 rockers you can use a universal socket with an extension and ratchet while it is running. Do one side at a time then run again to keep temps as close as possible. The change from 70F to 180F is big but 180F to 160F is small. Running is always better than not.
