OK... lusting after 275/35-18 on a 18x9.5
A friend loaned me his 18x8 with 6" backspace. That works out to a 1.5" offset. I stuffed a 245/40-18 on the 8 and bolted it up on my '68 Barracuda. The idea is a 18x9.5 with the same offset (6.75" backspace) and a 275 should work. The 275 being 1.2" wider overall, or 0.6" each side. I also tested with a 5/16" spacer to push it out a little to get a better feel for the clearance on the outside. So, plenty of clearance everywhere except one spot. May even run a small shim with the 275 to push it out a little. Even with the 245/40 I rub the frame at full lock. To keep off the frame I would have to drop to maybe a 255 on a 8.5 and run a bit less backspacing.
72BBSwinger, looking at your pictures it does not look like your wheels turn as far as mine?
Peter (GMachineDart) - this offset is pretty close to your set-up and I believe we are running the same spindle and brakes (Dr Diff "Brembo type"), and you are not seeing this issue either?
I guess I need to get the exact size wheel and tire and just test it or buy them and make it work.
