bamamopar
Is anyone running one? I'm looking for a little more top end and this is what recommends for my engine. Thanks Mark
Are you looking for more power, or it's not pulling cleanly? What are the ET, MPH, and incrementals? The 285HL is a great cam, but you should not be "running out of rpm" if that's the case. You may find it get's a little soft on the 60' with it, depending on how much the convertor likes the change. If it's a 10" convertor (the 9.5" shell) then it may not like it that much.
mph tells more of the story. It should be mph in excess of 87 mph or something isn't right.
The current build should be in the 400ish range for hp. At 3300# something isn't happy.
