[Found!] 2bbl. Carb for super six
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
I just picked up a 2 bbl. Intake manifold for a slant six, so now I need a 2bbl carb for it.
I am in colorado 81006 and i can pay with paypal only.
Thanks fabo
I have a 2bbl that was just rebuilt and tweaked to eliminate the flat spots that are known for the /6. Dyno tuned and rebuilt for performance by Bowen carbs. I'm moving from the /6 to a BB. Let me know if you are interested.
I am pretty sure the slant six carbs are unique to slants because the throttle arm is clocked different than a v8 2 bbl.
That type of logistics is easily worked out. If I were you, I would get a Carter 2 barrel from a 318. Cheaper, easier to find and will add some power. Do you have plans to upgrade the exhaust? If you don't, you may as well leave the one barrel on it. But if you do upgrade it, you will feel a noticeable difference adding the larger 2 barrel. Get off that original jag and use the 318 carburetor. Even with original parts, it's still not original.
