2dr sedan (coupe) carpet
Mopar Interiors
  1. jonnyrose
    jonnyrose Well-Known Member
    82
    14
    Aug 30, 2017
    canada
    Local Time:
    2:12 PM
    Howdy did the sedans come with carpet or matts,also havent seen any listings for flooring anywhere,are they the same as 2dr hardtops
    • Like Like x 3
    • R4Sedan
      R4Sedan Life in the Fastback Lane FABO Gold Member
      3,913
      1098
      Nov 26, 2009
      Tampa, Fl
      Local Time:
      5:12 PM
      You could get them with carpet or mat. When I did my Valiant it came with carpet. It was a Signet so that was standard. I think hardtop and sedan are the same. (as far as the carpet fitting).Been a long time since I did mine.
    • Cuda Al
      Cuda Al Well-Known Member
      738
      654
      Oct 21, 2007
      Lompoc, CA
      Local Time:
      2:12 PM
      The base models came with rubber floors.
      Any carpet set sold for an a-body should work, there is nothing about the different bodies that would make a difference in the carpet, even the dart with the longer wheelbase uses the same set.
      Alan
    • jonnyrose
      82
      14
      Aug 30, 2017
      canada
      Local Time:
      2:12 PM
      thanks so much for the speedy replies,
    • Demonic
      Demonic Well-Known Member
      429
      240
      Mar 21, 2015
      Maryland
      Local Time:
      5:12 PM
      Nice ride. Post sedans are cool - I hardly ever see any around here.
    • jonnyrose
      82
      14
      Aug 30, 2017
      canada
      Local Time:
      2:12 PM
      thanks alot i fell in love with this car,it was totally stripped so been piecing it back together,
    • Sedanman
      Sedanman 67-9 Valiant specialist FABO Gold Member
      8,437
      535
      Apr 3, 2009
      chicago Il
      Local Time:
      4:12 PM
      I'm not sure if Dart sedans are 111" wheelbase and I'd make sure both the car and the carpet are for the same wheelbase. All of the other A bodies are 108" wheelbase.
    • pauly v.100
      pauly v.100 Well-Known Member
      2,767
      173
      Sep 28, 2005
      honolulu, hi.
      Local Time:
      11:12 AM
      Should be the same carpet as a 2 dr. valiant.
      • Like Like x 1
      • jonnyrose
        82
        14
        Aug 30, 2017
        canada
        Local Time:
        2:12 PM
        sweet do you have a company you recomend
      • Mike69cuda
        Mike69cuda 64 is the new 17 FABO Gold Member
        578
        349
        Jan 2, 2018
        Overland Park Kansas
        Local Time:
        4:12 PM
        Just about everybody sells ACC carpet, so it will likely be the same stuff anywhere you get it. Shop for the lowest price plus shipping. Some places gouge you on shipping. Rock auto was the cheapest I found when I did mine earlier in the year. Lots of tips and opinions in threads here. I found them very helpful.
        I liked the mass backing option. Helps the carpet hold its shape.
        I also used the dynamat clone from Amazon, think it was Noico. Was about 1/3 of the price of dynamat. I really quieted the car down inside a lot. Just depends on time & $$ you have available for the job.
