2dr sedan (coupe) carpet
jonnyrose
canada
Howdy did the sedans come with carpet or matts,also havent seen any listings for flooring anywhere,are they the same as 2dr hardtops
You could get them with carpet or mat. When I did my Valiant it came with carpet. It was a Signet so that was standard. I think hardtop and sedan are the same. (as far as the carpet fitting).Been a long time since I did mine.
The base models came with rubber floors.
Any carpet set sold for an a-body should work, there is nothing about the different bodies that would make a difference in the carpet, even the dart with the longer wheelbase uses the same set.
Alan
I'm not sure if Dart sedans are 111" wheelbase and I'd make sure both the car and the carpet are for the same wheelbase. All of the other A bodies are 108" wheelbase.
Just about everybody sells ACC carpet, so it will likely be the same stuff anywhere you get it. Shop for the lowest price plus shipping. Some places gouge you on shipping. Rock auto was the cheapest I found when I did mine earlier in the year. Lots of tips and opinions in threads here. I found them very helpful.
I liked the mass backing option. Helps the carpet hold its shape.
I also used the dynamat clone from Amazon, think it was Noico. Was about 1/3 of the price of dynamat. I really quieted the car down inside a lot. Just depends on time & $$ you have available for the job.
