Total bullshit. They need to make things right. That's unacceptable. I'd find another way. Hell, coat a stock one with red Glyptal. Done. I mean seriously."Flat won't clear intakes with heat crossover" mentioned on web site.
I agree. He still needs a pcv. After he addresses the blowby problem.The area of relief with a PCV is very small. It is not designed to fix a ring blow by problem, but will help a small amount.
Why couldn't you? I've also heard that about not running the evac with mufflers. I hear Pam Anderson was a virgin, too.I seem to be learning something here. First, was told that I could not use a header evacuate on a car with mufflers. Second, run a PCV valve too? I mean, both at the same time?
