pishta
I know I'm right....
2012 Mommyvan: WTF, this thing is UNDER the lower intake manifold? Its on the oil cooler block that sits in the "lifter valley" between the cylinder heads. The sender is actually accessible with a long extension and a 1 1/4 deep 1/2 drive socket or a sensor socket. My GM 1 1/4 deep socket I got for the crank bolt worked great: The sensor plug JUST fits up in the round relief in the socket and the sensor I bought is a 6 point instead of the almost round looking stock ones. I am getting an oil pressure sender circuit malfunction on my CEL but its not flashing so its not a major alarm. A few tubers say to follow the manufactures procedure and remove the friggin lower intake (along with replacing the O-ring intake seals), a 2 hour job but a few more found they actually may have made it to be removed with a simple socket and an extension. Why would Mopar tell everyone to remove the intake? I can see for the oil temp sender thats mounted at an upper facing 45 angle, but this one is a straight 90 shot out the side of the engine. Will report back with results as soon as motor cools a little. The one coolant hose is right next to it, I hope its not in way or sensor clip is frozen on. RED one is sender. about 6" into motor from trans side.
jobs like this are the down side to wrenching on your own stuff
