They may be nasty cranks for your small block, but for the sake of all things holy, you can almost build a 408 Shortblock for the cost of that crank alone.
Oh i think cast cranks are just fine there was nothing cheap about my stroker build,it cranks out 520 h.p.i'm also running eagle sir rods and everyone keeps telling what "junk" they are,my stroker is living proof they work just fine...
333A well tune and designed motor will make more power than a stroker motor done by some one who thinks just and a crank and I have more power.In this case the opposite is true.To do a stroker kit,its just not a crank,rods,pistons.You need the cam and heads to match the flow reading of the new cubes.Its no use sucking big cubes through a garden hose,and the other end is true also,sucking cubes through a 6 inch fire hose does not work either.If the owner of the stroker kit,miss matches the wrong parts,the 360 stoker with the right parts will kick its *** big time.Please call Mr.Bobby Joseph at 1-770-443-8874 to prove this piont,mrmopartech
have to see to believe, but dont see getting more power with less cubes. my email is [email protected]A well tune and designed motor will make more power than a stroker motor done by some one who thinks just and a crank and I have more power.In this case the opposite is true.To do a stroker kit,its just not a crank,rods,pistons.You need the cam and heads to match the flow reading of the new cubes.Its no use sucking big cubes through a garden hose,and the other end is true also,sucking cubes through a 6 inch fire hose does not work either.If the owner of the stroker kit,miss matches the wrong parts,the 360 stoker with the right parts will kick its *** big time.Please call Mr.Bobby Joseph at 1-770-443-8874 to prove this piont,mrmopartech
Excellent street parts than can go racing. :salute:.
"street parts"...no!! i don't think so,but i'll have to remember that next time i'm at the track,when i'm beating up on the cars with all the race parts,and as far as getting 700h.p. out of a cask crank engine, i'm sure my builder could get that no problem...
Oh i think cast cranks are just fine there was nothing cheap about my stroker build,it cranks out 520 h.p. and put's my "street car" in the 11.0's,and i've got 2 seasons of racing on it too with NO issues pertaining to the CAST crank...i also might add it comes down to whos doing your machine work and assembling,i'm also running eagle sir rods and everyone keeps telling what "junk" they are,my stroker is living proof they work just fine...
