This is a stock 360 roller cam. What would cause the lifter journal to chip away like this?
Can you regrind a roller cam to a hydraulic flat tappet cam?
Do they make undersize cam bearings?
The 360 came out of any 89 3/4 ton pickup I bought used that I hated and didn't maintain very well. It was an oil leaker and oil burner. The idea was to save the cam as a core as there seem to be a shortage of cores. It's evident to me the bearing journals need to be ground so hence undersize cam bearings.1. I am going to say lack of oil
2. No
3. There are for some applications.
Your best bet is to just get a different cam.
Tom
