[SOLD] 3 MSD extension connectors. MSD distributor to MSD 7A ignition box
physixx
Edison, NJ
I have for sale 3 MSD extension connectors that go from the MSD distributor to the magnetic pickup connector on the MSD 7AL ignition box. These extensions would be used for big block applications where the ignition box is not in the engine compartment and subjected to heat but in the driver’s compartment where it’s much cooler. The long distance between the front mounted distributor and the box is what these are used to connect the two.
MSD Ignition 8860 MSD Replacement Cables | Summit Racing
One extension is 51” long and the other is 77” long with the MSD connector on one end and the spade terminal end to go directly to the 7A box. The third extension is 72” long and has the male and female MSD connectors on each end. The link shows the MSD distributor type ends but the two extensions have the connection that goes directly to the ignition box. I would like to get $8.00 each plus the shipping.
Ken
Edison, NJ
Either of the two in the top pic. The right one is the longer one. I'll put that one with the rest of your stuff.
