65LoveAffair
Whovian
I have never driven a car with a 3 on the tree. What is the shift pattern? Thanks in advance!
I have also heard that with early A bodies, there was nothing to keep you from shifting front 1st into reverse. Or any other gear into reverse. Is this true?
First is toward you and down
Reverse is toward you and up
Second is away from you and up
Third is away from you and down
These are all from the neutral position
Not a real good explanation but it's the best I can come up with without a drawing
I think you guys are on drugs....
"First is toward you and down" Wrong, it's towards you and up
"Reverse is toward you and up" Wrong, it's away from you and up
"Second is away from you and up" Wrong, it's away from you and down
"Third is away from you and down" Wrong, it's toward you and down
R 2
1 3
Tony is right!!!!! My very first car was 66 Valiant 3 on the tree. Exact same car as Memike's except it was white with red interior.![]()
"First is toward you and down" Wrong, it's towards you and up = reverse
"Reverse is toward you and up" Wrong, it's away from you and up = 2nd
"Second is away from you and up" Wrong, it's away from you and down = 3rd
"Third is away from you and down" Wrong, it's toward you and down = 1st
same here Tony No drugs.."except in a can or bottle" :happy10:Thanks Dave
I don't do drugs![]()
Try one of these column shifts some time!
R 3 5
X X
1 2 4
PITA! :iconbigg:
