[Found!] 3 speed wiper switch
I believe a '71 used the variable speed switch. I believe you'll need a 72+ connector plug (with wires removed from original connector and put in the 72+ if you want to use a 3 speed switch) as they had a different spade pattern. The 71's have 2 piece wiper plug which allows the same harness to be used with both 2 speed and variable speed switches.
