[WANTED] 30 spline 833 slip yoke wanted
I'll ask Steve,my buddy...He's got access to all kinds,of weird Mopar sheaahggt....
do they have numbers on them??
I have a box of slip yokes but I have no idea what I am looking at because I am not aware of too many differences ....how would I recognize a 1410 if I had one rat cheer
I have a 30 spline slip joint i have used for installing an 833 in my own car. Both OD and standard, fit better in the OD unit, I pulled out of a newer van. I am not sure if it what your looking for but I can send you a pic if you like, or you may even be able to find you own locally.
Here bees a drawing along with the measurements I need. Thanks yall.
  • Length to center of u-joint... Dimension #1 = 8.340 inches
  • Barrel Diameter... Dimension #2 = 1 11/16 inches
  • Barrel Length... Dimension #3 = 6 inches
  • U-joint cap diameter... Dimension #4 = 1 3/16 inches
  • U-joint width... Dimension #5 = 4 3/16 inches
  • Series... 1410
  • Spline count... 30
