TheCraigMachine
Hey guys, i gots another question for the experts. In adding up the numbers on building another 318 shortblock to replace the one that i blew, i just cant keep myself from going back to this idea:
What IF i picked up a 5.9 magnum engine from the auto salvage, with say maybe a 100k miles or so, pulled the mag heads off and threw them in the trash (because of cracks) and slapped on my recently reworked, milled, and ported 302 heads with bigger valves and springs already installed?
I know the biggest obstacle to this swap is the oiling, but i already HAVE two sets of hollow pushrods AND rocker arms from late 80's roller 318s, which used a combination of shaft oiling and pushrod oiling.
I figure the pushrod oiling alone should be enough to oil the shafts and valve tips, right?
Id want to run the factory roller lifters with the comp cams 20-746-9 that I already have in my possesion, which will yeild a lower net lift running the 1.5:1 rockers vs the magnum's 1.6:1 rockers. Havent yet calculated what that will actually be yet, thou.
My biggest concern is the compression ratio. More specifically, the compression height of the 5.9 magnum pistions, and the CC's of the piston dishes, if any. My heads have been milled .050, which gives me an 'estimated' 60cc combustion chamber. I intend to cc the heads asa get them off my old motor.
Any thoughts on this idea? Am i crazy for thinking that this will work? In my mind, if i can keep the compression under control, I think this would make for a proverbial rocket engine in an early A body!
