[SOLD] 302 Heads
12many
SC
From a 1987 engine: Rebuilt by Dover Cylinder Heads in Greenville, SC. Standard production grade valve job.
Hot tanked, valve job, freeze plugs, guides reconditioned (not knurled-they reline as needed only)
No porting, grinding, modifications
Stock Valves
Engine Pro machined chromoly retainers
Comp Cams 901-16 single springs w/damper
Setup for about a .460” lift Max HFT cam (or stock oem roller cam)
Approx .500” from retainer to top of umbrella seal.
Good heads for a stock or slightly modified 318
Just the reconditioning and assembly by Dover was $425 (price included the retainers) excluding the springs and heads themselves.
Price is $425 Firm. shipping is extra, if paid as PayPal goods and services buyer pays the fee as well
What is the install height on the valve springs? And have they been milled what is the cc of the chamber?
No idea on cc, heads were surfaced only to clean up, and I have no idea what the springs were installed at, I’ll have to check a few ASAP and post that. As to The cc’ing of these it is up to whoever buys them to check. Keep in mind these are purely stock reconditioned heads only with some stronger springs and retainers for a mild cam. They were removed from an 87 318 that had never been apart. Only one surfacing, and one valve job so they aren’t sunk, and have oem style umbrella type seals, the guides and spring seats have not been cut/machined. No cracks or repairs, I started to plug the air holes in the exhausts but only got two done so those need to be finished plugging.
Any way u would consider shipping ?
Hard to find in Hawaii and I sure could use them on my 273 build.
I'll take these but would need to be shipped to VA. Shipping would probably be close $150.00 but I'm ok with that. Please let me know.
Thanks
Nick
Installed spring height is 1.680” All valve stem tips have been dressed.
Also payment must be in full, No deposits, payment plans, holds, etc.
Postal money orders need to be sent promptly and the tracking # provided.
2 boxes, 22”x9”x8” and 65lbs each from zip code 29330 if you’re shopping shipping quotes.
$425 plus shipping or you are more than welcome to pick up.:steering:
Still available, have the standard bore 318 block, pistons & rods and uncut crank and various hardware etc that goes with it. Pistons were cleaned completely which are in great shape, bore practically no ridges, was intending on just cleaning up with bearings, rings, and a cam but changed plans. Selling piecemeal has run its course Need this stuff out of the garage. Comes with new Std rings Will post pictures of all included soon. All for $425 firm, no less. Come and get it!
Crank will polish up nicely (7/8 rod journal and #5 main shown after quick polish) All parts are 1987 318 roller LA.
Package includes: reman heads, block with caps, crank, timing cover, damper, misc bolts, oil pump pickup and drive. 4 pistons and rods, looking for the other 4 I’ve misplaced!
Timing cover, damper, misc bolts. At this time none of the following is included: missing 4 pistons (still rummaging for them!) one bank of rocker arms missing, no lifter retainer or dog bones, no block oil filter plate & threaded fitting, no cam thrust plate and related hardware, no crank balancer bolt. Only what’s shown in pictures posted.
