flathead5173
Active Member
I have a set of 308 heads that I'm going to install 2.02 intakes in and do a little bowl work. Do you have to worry about hitting water when working on the bowls of these heads. The exhaust valve is nailhead type and the 1.88 is a tulip type should I stay with the the tulip type in the 2.02 or switch to a nailhead.
