74 360 dart sport
Msd addendum for run ready distributor the relay from msd is 36.99 I dont know what the single pole double throw high energy means but wouldn't a guy be ok with a Bosch relay for 10.99
Single pole= one common contactsingle pole double throw
Well if you are running an MSD CD ignition box that makes absolutely no sense. The MSD CD box has a "big black" and a "big red" which are the main power and are to be run directly to a full time battery power. The "small red" switch lead already works much like a relay--it triggers the unit on, and requires very little powerYes msd says with the relay it will always have 12 volts with no surges up or down
