Hello All,
I am the Proud Owner of a Canadian Built 1960 Dodge Dart Pioneer 2DR Hardtop with the 313CID Polysphere V-8, Standard Transmission with a 8 3/4 Rear End.
I went out for a drive with the car the other day, checked the oil before I left it was 3/4 Full, did about 35KM, Oil light comes on, pulled over immediately, Oil level was on Add, checked for leaks no leaks. Topped up oil to full, then drove it home, lost 1/4 oil.
I did a compression test on each cylinder, Each Cylinder has 130PSI Dry, 135PSI Wet (teaspoon of oil down the cylinder) So Piston Rings are okay.
Im wondering if I should pull the cylinder heads, have them machined, replace the Valve Stem Seals & Head Gasket?
Any Thoughts or Ideas?? Greatly Appreciated
