dustinmoran91
318 with all stock bottom end, magnum heads, redrilled 360 four barrel intake, holley 600, howards cam with .501 lift 276 advertised and [email protected] has a 108 LSA and a 104intake centerline, cam is installed at 104, i know the intake is a restriction and the compression is a little low coming in around 8.5-9:1 on a good day. has a stock convertor for now and 3:73 gears with a 27" tall tire. car weighs around 2800 pounds from all the modifications i did. what do you think it will run?
my main reason for the stock convertor and intake was i had them layin around and a buddy with a ricer wanted to race so i thought i would just get it goin for now and try to whoop him and then upgrade those parts :cheers:
