318/904 So. Cal
pishta
I know I'm right....
Tustin, CA
I have a '78 318, looks to be a remanufactured longblock due to the warranty rivets on the heads and block plugs. 360 4bbl intake (a little crusty) or clean Holley street dominator intake included, will need intake gaskets. Spotless under the intake, pretty clean outside, no oil tracks. No sludge in the pan either (now has new outside powdercoated '65 273 pan) Cam specs out to or close to a small summit 6900 262/272, -.420/.442 cam using a 1" dial indicator in the lobes. Motor ran great 2 months ago, still has good 904 trans attached (will seperate) Electronic dist. HD 360 (86 truck) rockers. stock valve covers. 360 center dump logs or 68 318 logs, choice. Heads look stock, springs are a blue green color (?) sooty exhaust as well as piston tops as old carb was way rich. a Little seafoam should clean her up. Will include original starter with trans. $300 for the motor with cast intake, $350 for the motor with the Holley intake, $425 for everything. OR trade cast intake motor/904 for good running 225/904. So Cal only unless you arrange shipping, I dont own a truck so you have to come get it. Was offered for straight trade here in So Cal, but I guess a dog-pie 170-225 leaner is worth more than a rebuilt cammed 318? Who knew? .....Im going to buy a $125 dog-pie 170-225 with the proceeds anyway so a trade was in my best interest. Already got an injected 408 on the stand so the teen has got to make room for a turbo six project. PM
Gone...actually took a few days. You would think a deal like this would walk on its own...But I got my six and Loosnutz got a spare block and all the trimmings for his 408 build. Out...
Cool! I thought my magnum heads would sell quick too,but it took a looooong time.
