What "bands" where? BossHello. I need a diagram of how the belts should look on my 318 engine. It does not have power steering and no AC.
Thanks
Lol. I meant the belts. Going from alternator to water pump, main engine block etc. I eliminated the fan and placed an electric fan. It’s an older 318. Believe it’s a late 70’s.What "bands" where? Boss
Transmission?
fan belt routing?
what year / model are we addressing
smog pump?
From all I have seen, it ought to be just one belt around all 3 pullies. (I'm assuming no smog pump.) Like this:
Chrysler Small Block Alternator System (318, 340 & 360)
You have to have the water pump belt go around some other belt driven unit, as there is no way to adjust a crank to water pump belt alone. The point of adjustment would be at the alternator for this setup. The lower rad hose ought to be formed so as to bend under the belt section from crank to alternator.
