cudaracer
So I have posted in here several times seeking what to do with my stage II build, to mostly correct my stage I mistakes.
Stage I Build included,
-Top end rebuild on stock bottom end 72 318 with 904 auto, shift kit and 3.23 gears.
-Top end included 308 cast 360 heads (decked 20 thou), 0.028" head gasket, DP Weiand, eddie 600, dakota 360 log manifolds (love these btw) and a comp cam XE268h.
My complaints mostly had to do with no bottom end. Explained mostly due to lowered CR after decking at about 8-8.2, stock torque converter and the wrong automatic cam with a sweet spot at 1600-5500 ( especially since I never rev it past about 3500 rpms).
So now I have selected the following to correct and improve my situation, and thoughts and experiences would be greatly appreciated, as I also intend to write a lengthy piece about my experiences once done.
Stage II Build,
- since this is really a fix, as I am on a budget, I should really call this Stage Ia, but nonethelss, I am adding proform roller rockers (only $244 at summit) and the whiplash 318 cam.
The cam fits my automatic cruising drive style perfectly, with an idle - 4200 sweet spot and the Intake Valve Closing angle of only 30 deg ABDC, explains how they keep the dynamic CR so high with my stock CR. The comp cam was 60 deg by the way, explaining how I lost so much DCR as a result.
So with that cam sweet spot, regaining dynamic CR and roller adj rockers, I should see a significant gain to the pig I currently have.
Any thoughts on where I should be with hp and torque? I will have tested btw, so taking bets;)
Thanks.
Stage II Build,
Thanks.
