318 cam selection
R72Demon
Rome, PA
I am building a 318 for my 72 W100 Powerwagon. I need some help picking a cam. Heres the build as of right now:
1971 std. bore block
stock crank, rods, and piston
Melling HV oil pump
Cloyles double roller timing chain
#302 casting heads
Edelbrock performer intake
Holley 600 cfm carb.
Headers w/ 2 1/4" dual exhaust w/ flowmaster super 40's
Also my truck has a 4 spd. manual trans. and 3.91 gears. What would be the best cam for my application???
I'd go with the 272/272, .455/.455 Mopar Performance cam. What size tire does your truck have?
Comp XE262, Hughes HEH1523AL, the smaller 90360 Voodoo, stock 340 cam or something similar. 3.91's and 33's are fairly long legged, I'd go up a notch if you planned on 4.10's. I am running a comp 268H in my truck (1971 Jeep Gladiator, 9.0:1 350 Buick, TH400, 4.10's and 33's) and am about ready to pull it for a grind with 10 degrees less duration at .050 and a tad more lift. But then again, I drag a camper through the mountains... A 318 is really easy to over cam, so unless you are building a high RPM mud blaster, you'll be happier with a short duration cam.
