mikeyb0013
OK guys I need some advice. I had to redo my intake manifold as it was leaking after doing the 4 barrell conversion. I got it all back together and started it. It went to high idle and as soon as i touched the gas it stopped. Now it cranks and sometimes catches but seems to be running on 3 cylinders. I have to feather the peddle to keep it going and it eventually stalls and backfires through the carb. I reset the timing to TDC, replaced the ballast, electronic ignition, distributor cap and tested the coil. Still the same result. Any ideas?
Appeciate the input and suggestions.
Thanks
Mike
Thanks
Mike
