smallblockGT
Is there a decent moderately priced piston with enough height to bring a 318's compression up to say 9:1 to save some machine work? Hyper or regular ole' cast either one? Thanx guys
Already planning on a Balance job
what I did was to use 5.2 magnum pistons (melling brand) and even with 360 heads shaved .030 I ended up at 8.9 to 1 (more or less) on a 318. it runs real good even with the mid 80's 360 heads. fel pro gaskets I think
Ok made it out to garage today. My heads are actually #4027596 (81-83 hipo heads). My book just gives a range on combustion chambers for these, 66-72.5cc. Block #s are 4104230-318-2, I have two sets of rods 3418645 and 2899469. Are one of these more desireable than the other, also did mopar number the rods at the factory? Pistons that were pulled appear to be 1.755 comp height. So do I have more here than I thought or should I look for some fast burn heads? Again 9:1 is my magic number with affordable pistons and little machine work as possible. Thanx for all tour help and input guys. FABO rocks.
