staygold711
junior member
Daily driver 74 Dart SE 318 Is Barely running. At low RPM's it is running like it is miss firing. I had a small hole in my muffler and I thought it was building back pressure and thus causing the surging. I put a new cherry bomb glass pack on today but didn't fix it. So I changed the plugs, They were really wet fouled. Full of black carbon. Put new ones in but didn't solve it. Thought maybe somehow my plug wires were on wrong but nope, on right. When I start the car it takes too many cranks and barely catches then the RPM's start climbing way past the normal almost 2000 then it will kick-down to normal for a second then flux till it conks out unless you give it more gas. I just had the carter bbd rebuilt by a trustworthy guy. I tried to tune the carb but it doesn't matter if I put the idle all the way up or down. main jets up or down. Do you think I bent a rod? Or a piston is sticking? The fouled plugs says to me- oil or rich fuel mix but it was running fine until it didn't. I am not a engine guy so I will prob. be taking it somewhere when or if I have the cash. Anyone have this problem? let me know if you have any ideas. I really need some help!!! Stay Gold
