8) Im putting a 1992 318 magnum in a 1964 valiant with a 518 trans useing stock 273 engine mounts with slight mod , used 273 oilpan does not fit mag motor but refabed to work ,will use stock 273 exhaust manifolds will need to rise motor mounts up 1/2 inch to clear steering linkage. trans tunnell completey cut out to rear of rear crossmember. wiring harness being made at hotwire in mena ar.
