318 magnum vibration.
Magnum Engine Swaps
  1. Rick Wellman
    Rick Wellman Well-Known Member
    222
    23
    Feb 10, 2018
    Kenova, wv
    Local Time:
    5:56 AM
    i put a 2000 model 318 magnum in my 65 cuda. Bought a flywheel and bellhousing off FABO. Have a vibration in the engine. At 3000 rpms it vibrates pretty bad. How can I tell if I have the wrong flywheel. Are there numbers on the flywheel. I’ve heard that 318 magnums are externally balanced.
  2. dragbaron
    dragbaron Well-Known Member
    151
    48
    Dec 3, 2011
    Clovis, NM
    Local Time:
    4:56 AM
    The 5.2(318) magnum is internally balanced, the 5.9(360) is externally balanced. So two possible ideas are:
    Maybe you have a 5.9 and not a 5.2
    Maybe that flywheel came off an LA 360.
    • Like Like x 1
    • Agree Agree x 1
    • pishta
      pishta I know I'm right....
      14,248
      3921
      Oct 13, 2004
      Tustin, CA
      Local Time:
      2:56 AM
      Did the flywheel look solid (ie. no scallops cut out or weights added?) EVERY 318 was neutral balanced.
      Chrysler Small block
      • 318 A (POLY)-Internal
      • 273-318-340 (340 to 1971 Steel Crank) LA-Internal
      • 340 (1972 up w/Cast Crank) External
      • 360-External
      Chrysler MAGNUM Engine
      • 318 (5.2) Internal
      • 360 (5.9) External
      • 5.7l, 6.1l, 6.2l, 6.4l HEMI- Internal
    • Rick Wellman
      222
      23
      Feb 10, 2018
      Kenova, wv
      Local Time:
      5:56 AM
      I ran the numbers and it is definitely a 318 magnum. I pulled the engine from a 2000 dodge van. I bought a flywheel from Tony’s Parts on FABO. It bolted right up. Could he have sent me a 5.9 flywheel ? How do I tell the difference in a 5.2 and a 5.9 flywheel ? There are no scallops or added weights on the flywheel. Thanks for you guys replying. Rick
    • oldskool979
      oldskool979 Well-Known Member
      91
      65
      Sep 15, 2017
      Cumming,GA
      Local Time:
      5:56 AM
      Did you change the harmonic damper to an aftermarket unit? They are also specific to internal/external balance.
    • Rick Wellman
      222
      23
      Feb 10, 2018
      Kenova, wv
      Local Time:
      5:56 AM
      No, I used the original but went to v belts instead of serpentine
    • Maistrelli
      Maistrelli Active Member
      40
      15
      Jul 16, 2018
      Ohio
      Local Time:
      5:56 AM
      What are the differences between 318 Magnum and 5.2 Magnum? I thought 318 was LA engine and 5.2 was Magnum.
    • Bobzilla
      Bobzilla Well-Known Member
      492
      314
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      5:56 AM
      They are just interchanging terminology. Magnums all used the size designation in liters, so 5.2 Magnum is 318 cubic inch Magnum and 5.9 Magnum is 360 cubic inch Magnum.
      Balanced parts, like harmonic balancers, flex plates or flywheels, and cranks, roads, and pistons are specific to each family of engine, unless the parts are balanced properly before use.
      Edited to remove LA engine from last paragraph.
    • Rick Wellman
      222
      23
      Feb 10, 2018
      Kenova, wv
      Local Time:
      5:56 AM
      The 318 magnum is a 5.2 magnum. No difference. Just my terminology. I’m old school and still use the cubic inches instead of liters.
