dodgetkboy78
EDELBROCK HEADS SUCK!
So this isn't an A body engine question, but I need some opinions.
I have a Boat, with a 360 in it. It has the little single plane 4bbl manifold on it from the 318 it replaced. What effect do you think the little port manifold has on the big port heads? I have put 318 heads on 360's for hunting buggy's, and low low rpm work engines, but never a small port manifold on a big port head.
My only main question, since I am happy with the power, (The boat cruises at 8kts, 2000rpm, throttle barely cracked) is what it is doing to the economy. What do you think I would benefit if I put the dual plane 360 marine manifold on it?
