Hello everyone,
I have a question about the correct oil for my Dodge Dart 75 engine V8 5.2, in the owner's manual, it indicates only SAE30 oil.
To replace this old type oil, what would be the best oil to use? Here where I live in Brazil the ambient temperature is around 15-35 degrees most of the year
My dodge has no preparation, but the engine has been fully rectified with all new internal parts a 5 years ago.
Just for information, in my engine specs manual, it indicates the minimum oil pressure of 20 psi at 550RPM and 60-80 psi at 4000RPM.
In conversation here with other car owners, I found many differences in the oils they use, for example, 15w40, 20w50, 5w30, .., and they didn’t know how to explain it, just someone indicated (repair shop) and they continue to use ...
Thank you in advance.
