318 or 360 - What to Build
I have been doing a fair bit of reading on performance upgrades and have a few questions for you guys. again keep in mind I'm trying to make this a budget build
There is a local guy that is going to sell me a Weiand X-celerator intake and used headers for a 340/360 for a combined price of 400$ CAD.
if i pair this with the following:
  • 360LA motor
  • .508/292 purple cam
  • Weiand X-Celerator Intake
  • 750cfm carb of some sort
  • home ported j or x heads with 2.02 valves
  • long tube headers and 2.5" dual exhaust
  • 4:10 axle gears
  • 727 trans with 3000 stall (eventually I will A833 Over Drive swap it)
  • I believe I will need to get domed pistons to boost pressure up around 10:1 - 10.5:1
  • this would likely require premium fuel which is fine for me
will this be to gnarly of a setup for ripping around on the streets and minimal highway driving?
will i need upgraded valves, springs and retainers, and a beefy cam timing chain set?
I believe that that cam makes its power above 3000RPM and the intake is good for something like 2500-6500rpm
I run that cam with 3.91's and it does well in the street. I advanced it 4° @ the crank. I just run KB107 flat top pistons. 340 X-heads (unported)unsorted. Cam sounds so good @ idle!
