Success! Thanks again.
I pulled the damper back off and had a close look at everything. I found that my bolt would not easily thread into the crank, so I cleaned up the threads best I could without having a tap/die that size, and I got it moving more freely. I think it was binding and giving me a high torque reading before actually seating the damper. I lubed everything back up, re-assembled and torqued it together, and now I have only maybe .040" between the timing marks and the damper, and my pullys are well aligned.
My only question is: How far should you be able to seat the damper onto the end of the crank, before relying on the bolt to pull it in? I could barely get mine started, and only had just over 2 turns of the bolt engaged before I had to start tightening... and crossed my fingers that I wasn't going to strip out those two threads.
