318 roller engine long block needs rebuild/clean
seymour_scamp
Seymour, Indiana
This motor was running but ticking when I pulled it. One of the roller lifters broke and some pieces of it went down into the engine, so I was going to just pull the pan, clean it out and put it back together but went with a 360 instead. You can see in the picture why it was ticking, part of the lifter that was left was hitting on the cam.
Motor and heads are very sludgy, but had good compression.
all stock 1988 motor
Has 302 heads, stock roller cam & lifters, spider - missing one lifter.
Has 90 deg oil filter adapter on it. I also have the a-body exhaust manifolds if you need them. Has Car oil pan.
No intake, no water pump, no alternator, pullies, etc, no motor mounts.
asking $200
Pickup only in Seymour, IN 47274
Its currently on an engine stand and I have a hoist to lift it into your truck.
