DQ81
'73 Dart
Started trying to track down the reasons my 318 runs inconsistent below 1500rpm, the skips, misses. At a stoplight it feels like it's gonna choke one second and tries to lunge forward the next...
After using a vacuum gauge to set the carb up today I did a compression test.
Results not so great:
around 105 psi per cylinder, the lowest being 101 and the highest being 108
I also noticed my spark is really weak. So I'll check for ground issues asap, replact the cap, rotor, wires and coil with an internal resistor...
My charging system doesn't charge wel under 1500rpm...any possible link to the weak *** spark I"m getting?
Gettin' kind of bummed with this car, it's just one thing after the other, the money and time pit... With that kind of compression I'm just gonna look for a BB or a 360 to chuck in it for sanity's sake...
