318 to 360
69 fstback
well hope you guys got the answer to this one pulled my 318 sat first problem oil pan from 318 wont go on 360 call summitt order new pan next problem motor mounts wont bolt to 360 block any body no what mounts i can use car is 69 barracuda original 318 swapping in new 360 any help would be great thanks
The 318 mounts are wider than 340/360 mounts on the drivers side. Use washers to take up the slack. Sometimes, brackets from different years and different cars interfear with the block. I had to grind away on my 318 brackets for my 360 to fit well so I can use all the bolt holes.
had the same problim going from my 318 to 360.On the right side the 318 mount was good to go,on the left the 318 mount did not have that extra hole.So my buddy next door welded a plate on and even drilled the hole took him all of 1 hour to make mine work.You could buy the right mount.
