64 SRT8 Dart
Would appreciate if any of you dyno/pro engine builder/dyno program guy/gals could enter my info or give a good guess at what hp/trq my 318 combo would make. I'm at around 6000ft elevation. It would be very much appreciated!
318 .030" over.
Stock cast crank .010/.030 under. Balanced assembly
Cast flat top piston..zero deck
Bushed stock rods
10:1 compression
Stock volume oilpump
Performer Intake
Lunati cam .465/.465 228/[email protected]"
Cloyes double roller t/s.
Holley 650 SB DP w/ 1" spacer
Iron 973 smog head w/1.75 I / 1.5 E valves. Gasket match/bowl blend/shape,remove guide areas/slight porting /60cc chambers/ 3 angle valve job...(not sure of angles, prob close to stock)
Crane 1.5 roller rockers
Hooker headers 1 5/8" prim, 2.5" collector
Factory Electronic Ign.
Also, wonder what this combo would run in my Valiant...1/4 times??
Trans is 904 w/ TF2 kit, Alto Red clutches(extra clutches as well) Kolene steels, red lined bands.
2500 stall convertor.
3.55 gearset on street tires, lol.
Stock 66 Valiant rear springs and shocks
Car is around 3000lbs w/me as driver.
Very much appreciated!! I'll take a guess and say around 300hp/330tq
318 .030" over.
Bushed stock rods
10:1 compression
Performer Intake
