My 318 build has me scratching my head. 1800 miles on the new motor.
It's zero decked with 1.81 KB forged pistons, .040 overbore, Indy/Rhs LA X heads with 1.92/1.62 valves, 62 cc closed chambers. .042 quench, a Comp XE268H cam, a holley 4150 650 cfm carb, Eddy air gap intake, a pertronix flame thrower II billet distributor and a timing chain tensioner. It's got 2.94 rear end gears for now (3.23 being assembled now in the garage) and about 9.6:1 compression. Intake centerline is installed at 105.5 on the degree wheel.
At the wheels 281.32 HP @ 5790 rpm and 257.65 torque @ 5690 rpm. pulls done in second gear because of the rear end ratio. 92 octane, 10% ethanol. Oh, and I'm going to up it from a 1700 to a loose 2000 or 2200 stall converter to help with in gear and engaged A/C compressor Idle quality.
air/fuel ratio was good but at higher rpm was leaning out so upped 3 secondary jet sizes and came in good @ 12.76. float bowls are running dry at higher rpm so I do need a better fuel pump.
Here's the thing. This pertronix distributor has the 16* stops in it with 1 light spring (Copper color) and 1 medium spring (Silver color) on the mechanicals. Initial is set at 18* BTDC...that should give me 34* total...vacuum advance disconnected and plugged. I would guess it should be all in by 2800 to 3000 rpm...well, it's not and total advance is not 34*. It's all in at about 3800 and total advance is 40* BTDC, no detonation. We didn't take it any higher than 40*...tech said he thought that might be pushing it.
The Dyno showed that it likes this timing. Moving the distributor for 36* BTDC same springs, same stops dropped 25 hp. 34*BTDC dropped 31 Hp.
The pertronix mechanical stops are cheesy at best. Had them jam up the mechanical advance before and it seems that they also aren't holding timing.
Any one else have problems with the pertronix stuff?? 40* seems like a lot but the dyno proved it to be good so that's where it will stay as long as the distributor will remain constant...I don't trust it anymore.
I just ordered an FBO HEI setup with limiter plate. I guess I should call em and tell em the dyno results so they can set it up accordingly but at 3000 all in.
40* has me scratching my head...any one else have similar timing numbers???
Opinions????
Opinions????
