340 1.88 intake valve coloration normal?
dibbons
La Paz, B.C.S., Mexico
After cleaning up the intake valves in a used 340, found a pretty rainbow hue to them. They don't appear to be bent, warped, or melted. They still have plenty of margin left. Is this color unusual for a used valve? Thank you.
If the stems are within spec, and .0005 or less taper, I grind the face. If it cleans up with minimum grinding, I'll back cut and run them. OEM HP stems are typically .0005 smaller in diameter.
I don't see a problem with it provided it's still in good shape aside from the coloring.
